Hello Guys,
I am doing an Entertainment System that will be housing some very heavy Audio Video Components. (upwards of 150- 180 lbs per power amp.) This is for a showroom in a high end home theater company near me. I plan on using 1\" ply on the shelves. They want adjustable \"blind\" or \"concealed\" shelf supports so that the supports are hidden.
Does anyone have any ideas on a good blind support that can carry such a heavy load ? . All the weight will be distributed close to the ends of the shelf where the component feet are located so the supports will bear the brunt of the load.
Also, somewhere out there I beleive I seen pullout hardware for media storage similar to hidden spice rack pullouts behind fillers and pilasters. Is there specific hardware for this purpose? or are you guys just using the Rev a Shelf Spice Rack Pullout hardware (or some other brand )for this purpose and altering it to work with media ?
I did something like this once but I can't remember the particular supports I used. I can tell you how they worked though.
They were like normal heavy duty shelf supports with standards that are dodoed into the back. The brackets themselves fastened to the sides of the shelves instead of underneath.
Vince...
I have seen some that are perhaps good for your aplication...
They were a quater inch dia rod that was bent to stand off the side of the cabinet about 3/8 to 1/2 inch. Each end of the rod fits in to the shelf support holes in the side of the cab... I will try to find the source and post it here...
Michael
