Brian Fox
Posts: 13 Joined: Fri, Jun 24 2005, 6:07AM
Post
by Brian Fox » Thu, Mar 01 2007, 7:11AM
OS= XP SP2
I clicked on the link v5.1 at the sticky in the forum, it downloaded, got the RUN option screen, clicked run and got this.
\"The package could not be opened. Contact the app vendor to verify that this is a valid windows installer patch package.\"
Any ideas?
Oh ya, If I try to updaye through e-cabs it states that I have the most current update, V12.
Thanks for the help
Brian
Justin D Melhiser
Post
by Justin D Melhiser » Thu, Mar 01 2007, 8:35AM
Brian
Did you try to save it to your computer instead of opening it and then run the update?
Brian Fox
Post
by Brian Fox » Thu, Mar 01 2007, 8:43AM
Yes, I tried downloading it both ways. I also tried updating with in e-cabs. No luck.
Any other ideas?
Brian
Denis L'Heureux
Posts: 407 Joined: Tue, May 17 2005, 12:41PM
Post
by Denis L'Heureux » Thu, Mar 01 2007, 9:20AM
I also have an issue with the installer. All seems to be going ok and installs fine but when I open Ecab and check on the version type, I still get 5.0 build 12 and that is all that is on the screen. It is very slow as well.
Cheers
Justin D Melhiser
Post
by Justin D Melhiser » Thu, Mar 01 2007, 9:56AM
Brian
I am sending you an email. I want you to try a couple of things. If you need to contact me my number is 1-800-533-6901 ext.227
Mike Snodgrass
Posts: 70 Joined: Mon, Nov 28 2005, 10:12PM
Post
by Mike Snodgrass » Thu, Mar 01 2007, 9:55PM
I am getting the installation source is not available also.
Also it says verify that the source exists and you can access it.
Can somebody help a fellow ecabber ?
