Board foot......V5 or V5.1?
Denis L'Heureux
Post by Denis L'Heureux »
Am I still running v5 or am I running v5.1?
I downloaded and installed the latest version but I get the image below and it is still saying Build 12. Also, I can not for the life of me figure out how to set my board foot pricing. So I figure I am still on v5 and not v5.1....
When I check for an update through the software, it says I am running the latest version....so I figure I am running v5.1 and no longer v5...
Oh I am getting a head ache...
Help...I need to get my board feet sorted out.
Tx
Which version.jpg (14.76 KiB) Viewed 14126 times
Joe Soto
Post by Joe Soto »
Looks like your still on 5.0 The splash screen and shortcuts should say 5.1
You're still on 5.0. The only way you can get it is to download it from the link in the sticky at the top of the forum...the Check for Update doesn't work for 5.1.
The file name is eCabinetSystems5-1.exe and you can execute it if you downloaded and saved it. Make sure you save update files instead of trying to run them via download.
Denis L'Heureux
Tx Joe
It sure looks that way but then again, when I check for update, it tells me I am running the latest version....Is that normal?
Joe Soto
Post by Joe Soto »
I guess thats because you have the latest update for v5.0 Have you tried to install 5.1 again?
Re:
Denis L'Heureux wrote:...when I check for update, it tells me I am running the latest version....Is that normal?
See above Denis...
Denis L'Heureux
Tx Dan
I had saved it in a folder and executed it from there. I did tried to set it up several times but it just won't take. I am trying to download it again. It might be corrupted. I will try and run the update patch again and see.
Joe Soto
Post by Joe Soto »
Got ya Dan :joker:
Re:
Joe Soto wrote:Got ya Dan :joker:
Yep...I take a 30 second break and see what happens :lol:
Denis L'Heureux
Nope...it just won't take. I downloaded it again to my hard drive and re-installed but I still get build 12
Joe Soto
Post by Joe Soto »
Denis, not sure it makes any difference but have you tried to just run it instead of saving it first?
Denis L'Heureux
I guess I can try that Joe....Nothing to lose at this point.
Denis L'Heureux
Nope...tried to install without saving and it still won't update my version.
What else can I do?
Justin D Melhiser
Post by Justin D Melhiser »
Denis
Make sure that ecabinets is shut down when you try to install the new 5.1 also if thats does not work delete the old files of 5.1 down loads and go to ecabinetsystems.com and click on updates, then download the file, make sure you save it to your computer and not jsut run it.
Denis L'Heureux
Justin D Melhiser wrote:Denis
Everytime I try to update, I do make certain that Ecab is shut down completly. The update seems to be of the proper size but when I run it, it only takes a few minutes to complete. It seems very fast for 22+megs to install.
Which file should I delete when you say "the old files of 5.1 down loads" Are you talking about the one I downloaded from the link at the top of this section? I have downloaded it three times already and it does the same thing everytimes.
I am now in the process of downloading the one from Ecabinetsystems.com and see if I get better luck with that one.
I will keep you posted.
Cheers
