Conestoga Casing Miters wrong.
- Kerry Fullington
When I cut a miter on the Conestoga Colonial Casings to use as a door casing, the miters are backward. A door casing will miter with the thick edge to the outside. How can I change this?
- Scott G Vaal
- Scott G Vaal
Kerry,
In case you do not know, you can use edit molding to change these miters. That way you do not have to delete it and add it back. Just select the molding (one at a time) and look in the r-click menu for the option.
- Kerry Fullington
- Roger Erismann
- DanEpps
- Company Name: Dan Epps
Re:
RogerRoger Erismann wrote:kerry didn't know?????
I better see if the sky is falling
When someone recently said something similar about me, I said "Libraries are filled with the stuff I DON'T know."
I have to agree with you here though. In Kerry's case the library of unknown stuff would be more the size of that small stack of books in the bathroom.
- Kerry Fullington
Michael S Murray
Kerry,
I am the one who learns just enough to get the job done,acceptable drawing for client, accurate info for the router. You my friend, go quite a ways past just enough!!
Mike Murray
mike@versatilecabinet.com
- Denis L'Heureux
Re:
Except that the job you get done is WAY more complex then that of the common mortal. So that "Just enough" part is way beyond what we all know....Kerry Fullington wrote: Like everyone else I learn just enough to get the job done.
Michael S Murray
Oh Yeah, about testing Scott. E-cabs is a mere toy in the mans hand, his talents go way beyond to the machine and actual understanding of how it all works, he actually understand those 60 to 70, 000 lines of code and how to get that machine to do just what he wants. Scott and a couple of the other guys at thermwood are right up there with John Wayne and Eric Clapton in my Book.
Mike Murray
- Scott G Vaal
Kerry,
I was scratching my head wondering why this wasn't obvious to you and others and realized that the picture, “that use to be there”, depicting this positive and negative ability is missing from the page. I will get it back so that the ability is recognized. Sorry for the confusion.
- Peter Walsh
