crashes when changing material
Mark Hesketh
just finished putting together a cabinet when i was informed that the material of some parts had to change. but when i go in to change the material, ecabs crashes right out as soon as i hit the OK button.
can anybody figure out why or tell me how to get around this problem? her is the cabinet i am talking about
- mat change.zip
- (361.2 KiB) Downloaded 596 times
Michael Yeargain
greg youngken
- Company Name: Grali inc.
I took this cab to the cab editor and the file is shutting down my program too. Where you in the middle of changing mat. or something, I noticed the edge banding is specified as something different than shown on cab? Check your material settings in the setting preferance area there is no image assoiated w/ your 3/4\" burgandy ?
Grali inc. / Greg Youngken
grali.com
grali.com
Michael Yeargain
I found that If I open the construction settings and click OK it crashes.
This one is nuts...
While in the shelf editor e_cabinets tells me I can't delete a fixed shelf with a partition attatched to it. 4 fixed shelves remained undeleted. Now after several attempts to delete the shelves, I am finding two fixed shelves that I can't delete.
This one is nuts...
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
32Gigs DDR4
Corsair RM650
greg youngken
Mark Hesketh
so... it crashes on me when i go into construction settings and then hit ok in the cabinet editor. it also crashes if i try to enter the edge-banding area. it also crashes if i try to change sheet stock in the batch editor. it also crashes if i enter the construction settings from within the shelf/partition editor. it also crashes when i try to exit from the constraints manager. basically, there seems to be no way for me to go in and edit this cabinet. the worst part is that this cabinet has dowel construction, so there are series of holes for each shelf that i will now have to go in and re-enter... just frustrating.
Thanks for taking a look at it though folks, and for the help. at least i know i'm not just crazy
- DanEpps
- Company Name: Dan Epps
Mark:
Something in the file is causing a stack overflow when the cabinet is regenerated. If you can remember the last thing you did to the cabinet it might be helpful to the programmers in determining what caused the error.
Thermwood team:
The specific crash dump info is
the assembly instruction at HOOPS1106!HC_Compute_Matrix_Product+2c4267 in C:\\Program Files\\Thermwood\\eCabinet Systems\\HOOPS1106.dll has caused a stack overflow exception (0xC00000FD) when trying to write to memory location 0x00032fdc on thread 0
Thermwood team:
Mark Hesketh
i think that the last thing i did before saving it was adding the constraints to the top and to the lower shelf... and it saved fine. didn't try to change materials or anything at that time though. it was when i re-opened it, and ever since then, that the crashes have happened.
as it is now, i have managed to recreate the cabinet, and it seems to be working fine. thankfully you can save your part editor cuts as a pattern and re-apply them
that saved me a whole chunk of time.
thanks again for checking it out
oh, Todd, got your voicemail, but i think this should explain everything better than what you would be able to get from me trying to yell over the noise of the shop on the phone (my computer for ecabs is right beside the router in the middle of the shop, so they can have me run both at one time)
let me know if you need any more info.
Todd Miller
