Problem with elyptical geometry
DanFecteau
Post by DanFecteau »
We do a lot of archway doors, one of our new standard is elyptical arch way, it's fast and easy to draw but I have problems when I machine the parts, when the cutter get in the \"curv\" its's do little \"jumps\" ??? Is it the machine, mastercam, autocad ????
Pete Riddle
Post by Pete Riddle »
Dan,
Most of your CAD softwares output ellipses as splines (or small straight line segments. Your machine is most likely reacting to the series of small straight lines. I recommend you convert your ellipse (spline) segments to arcs. That will solve your problem. I have been using Mastercam to accomplish this here.
DanFecteau
not working ?
When I do that, modifi, cnv to arcs I get \"no spline were converted\" ? What am I doing wrong ??
DanFecteau
break, splines to arcs
Ok I got it with Break, splines to arcs, I'm gonna machine it now.....
