Hi Jeff...
We are a small cabinet shop cutting primarily 1/4\" thru 3/4\" plywood. We're not a production shop, so I know there are methods for increasing production over what we produce, but at the moment that's not my primary focus.
We have a single person load, machine, label, sort and stack the parts...don't forget you have time loading the file, loading offcuts (if available), nesting the file, printing the sheets & labels and then finally writing the CNC file before loading the first sheet on the router!
Obviously the number of sheets cut per hour depends on the size and number of parts on each sheet as well as the size of the sheet material itself. For example if you have a job with a huge amount of drawers you can end up with 30 to 50 parts on a single sheet. It not only takes longer to machine because of the number of different type cuts and tool changes, but it takes time to label, sort and stack. You may only get 2 sheets in an hour - however if your running 1/4 plywood backs through you might be getting 2 to 6 parts to a sheet with only an outline cut and producing 6 or 7 sheets an hour.
Our shop will average 3-5 sheets an hour based on an 7-9 hour working day. Which means we can cut an average to larger size kitchen in a single day. We also use prefinished plywood (one side) which means our cabinets are basically ready to assemble once they have come off the router. In addition everything is also labeled and stacked on carts as a unit so we can be fairly productive in the assembly process as well.
As far as the most number of sheets cut in one day - We had a large job (over 60 sheets) that I and a helper cut in a single day...it wasn't an 8 hour day though! I know we can hit somewhere around 30 sheets a day with out too much problem.
Hope that helps...if I can be of any additional assistance you can send me an email and I'll be happy to see if I can be helpful
Mark
mtaylor@handymansolution.com
