when trying to delete items in a custom layout I can't delete the cabinet assy. the counter top and display cube go with no problem but when I choose the cab a popup says reorganising cabinets and my system freezes up. the cabinet I am trying to delete is the only base cabinet in the layout so I don't know what is being reorganized. I have attached the room. thanks.
John,
This is a known bug.
Workaround:
Select the assy.
Right click and choose \"edit Assy\"
When in the editor, delete cabs or the whole thing and then return to the room.
Done
regards,
I had an assy that I was trying to delete withe the same results. I was given the same advise. My assy consisted of two cabinets. I was able to delete one of the cabinets but the software wouldn't let me delete the other. I had to go into the construction menu and uncheck all the boxes, deconstruction the cabinet. When there was nothing left I returned to the detail room answering 'yes' to the save changes question. Slow, definitely a workaround, but it does work.
