Collets
Bill OConnell
Collets
I have read that a collet should be replaced after 3 mos. if you are using it 8 hours per day. Not closely watching the nine tools I have set up on our machine, is there a way to visually examine the collet and determine it needs to be replaced?
Woodworking the Way You Want It
Ryan Hochgesang
Hi Bill,
You should be able to see some visual wear (discoloring, or feel of divet with fingernail or sharp object) inside the collet where the tool is clamped in. If you want to watch the tools closely and stick to the 8hrs/day for 3 months, you could use the Tool Manager (F10, F9, F2), Life Left value.
Hope this helps.
Hope this helps.
Mark Hesketh
I have to respond to this also. We've run our machine average 4 to 5 hours a day for over 4 years and still use the same collets. I'm not quite sure I understand what is going to happen other than maybe I lose a tool. I can understand if you are getting chatter or some other poor quality cut but this is not happening.
Ryan Hochgesang
Mark Taylor
Ryan Hochgesang
Oops! Sorry about that. Forgot to attach it
- ColletMaintenance.pdf
- (278.62 KiB) Downloaded 1105 times
Michael J Starry
Ryan Hochgesang
Michael J Starry
I figured as much. I find Denatured alcohol is good as well. I mainly mentioned the carb/brake cleaner to make a point to our maintenance guy. He uses bcarb and brake cleaner, and is known to spray WD40 into the spindle to lubricate the drawbar and clamping set. I have argued with him about the risks involved with both practices, so I figured it would be better to get it from Thermwood themselves to prove my point. Yuo know, what do I know, I am only a Programmer....
Eric Montbriand
collets
Hey guys, i thought id put in a few cents here. We use a product called Rust free on our collets and holders where there may be rust like build. It comes together with another product called T-9 which is a waterproof lubricant, both are made by Boeing. We use another product called LPS, an industrial lubricant. The LPS is greaseless and is not petroleum based like WD-40 which can attract dust. These products and a gray scotch brite will make our tooling look new.......ish.
We've never done anything to the drawbar for lubrication, as far as i know, nothing should be spayed or blowed up there. A machine tech showed me that a small amount of grease on the tip of a finger, while the drawbar is actuated, could help maintain it.
Collet wear could also be on the mateing end where it sets in to the tool holder nut. I've seen the metal worn,pitted, and ridges on the inside. A good check of the collet would be to take a bit and put the shank in one end of the collet and then the other end. The tension should be the same, the bit should not drop through the collet either. If you get large piting on the taper of the tool holder, id replace it. We cut corian, a countertop material thats very abrasive and tough on solid carbide. We are currently running our cut outs at 1,000 IPM!!!!
Eric M
Eric M
