I've been trying to create curved crown molding in the part editor. In the shape manager I was using the spline tool to create the necessary curve needed for the crown.
The spline tool doesn't act like any of the other tools...you cannot extend the length of it with the tool - you cannot trim the ends of it with a crossing line, circle or arc nor can I move it with the move tool.
This is the first time I have used the spline tool...so I'm not sure if it is working correctly or not (?)
Mark
spline tool
Mark Taylor
Leo Graywacz
You might as well not even use it. The program does not handle the spline well at all and the routers will not cut anything using the spline because it cannot be turned into a mathematical equation. You will need to figure out a way to make the curves you require with arcs. This way the program can integrate them into useful information.
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
- Brian Shannon
