Channels cut into an MDF sheet??? that would be what I would call a \"jig\" -Ummm... is there anything wrong with that?
First, if we included a 1.5\" thick sheet of trupan into a job to be milled into a jig for holding faceframe parts on end, because that is exactly where I'll want to try this first, how will the router \"index\" to the jig once it is loaded with solid stock parts? I'm supposing you would mill out the jig, then load the FF stock into it without moving anything, and cut your mortises & 75% of your tenons on the very next operations? wait, nix that... unless you can clean tenon shoulders with a magic wand...
what kind of fit tolerances would you use for the width of the channels?
what size/spacing would you bore through the bottoms of the channels for vacuum?
Here's another thought... Does anyone here use \"Beadlock\" joinery system?
For those unfamiliar, you mill your stock with one of the Beadlock router bits (I mill mine with a shop made insert knife on the shaper) the routine is to use the beadlock drilling jig to drill (usually) 3 overlapping holes which comprise the mortises, the stock, CTL, is your loose tenon and they go together well and make a strong joint.
Might this type of system be worthy of consideration for a NEW ecabinetsystems FF joinery option? Because hypothetically, it might be alot easier to produce on the CNC than trying to jig up/flip-op yourself to death trying to produce true M&T.
Only one manual shop operation could simplify this process to completion if one were to setup a dedicated station for end boring.
Any thoughts, opinions or dirty looks???
