If I am understanding correctly, we take an item into SHAPE; create tooling; apply that tooling to very specific points on that item -be it a cabinet side, display cube or stainless steel dishwasher
Once we return back to the cab/assembly designer, THAT specific part, as it was sized/milled during the shaping process is what you have to work with????
creating custom tooling... If I'm wanting to cut a BUNCH of stop flute parts of various sizes, would it be better to chuck up a 1/2\" core box bit?
As I am understanding this, the tooling \"created\" here relies on a tiny ball end cutter and a straight bit with MANY multiple passes to execute the MODELED shape you command cut.
Also, do I need to be concerned with the direction and number of passes for a cut. E.G. If I S4S 6/4 cherry and intend on cutting stop flutes and edge profiles, what dictates how much is taken off per pass, whether that pass is push-cut or climb cut, etc ???
