Build 3 Bug....
Scott G Vaal
Post by Scott G Vaal »
Jerry,
You can resize with the change size button without any problems as long as you understand the glitch that currently exists in Bld. 3 and make sure that the height is set back to what is needed. Make sure to keep in mind that when the cabinet is set to a detached toe the height of the cabinet includes the detached toe height! I think this is where you are getting confused. So, if you save a detached toe cabinet in Bld. 3 that has a 4\" detached toe and the cabinet height is 34.5, (which is what your cabinet you posted here was saved as and creates a box height of 30.5”). Now, when you select the define size button it will fill the height entry box with 30.5\" but should be 34.5”. At this point all that needs to be done is to set the height back to original, which would be 34.5\". If you do this it will place the cabinet into the room at the proper value for height (I tested this with your cabinet). If you let it at 30.5\", it will place a cabinet with a total height of 30.5\" and the actual height of the box will only will be 28.5\". Hope this helps. This issue will be resolved for the next build due out in the near future.
Jerry McClain
Post by Jerry McClain »
I understand what you are saying Scott, I was taking into consideration the detached toe. It was not consistant with the height of the cabinet, what I did was reinstall ecabs and now it is acting in a more constistant manner. I don't mind doing the work around, entering the 34.5 and all but what was concerning me was the openings of my drawers being changed everytime that I did that. I have that working as well as it can at this time. Now I have a new problem, I have a layout in a bathroom, I placed a cabinet at each end leaving a opening in the middle for a drawer stack. The opening is 18.25\" so I designed a cabinet that is 18.25 wide with a height of 35.375\" to match the height of the others. When I try to place said cabinet into the opening it asks me if I want to resize the cabinet to 18.25. If I say no, you know what happens, if I say yes it changes the height of the cabinet to 30.375. What have I done now!!!
JLM
Scott G Vaal
Jerry,
Attached the job and the cabinet that you are trying to place between the existing 2 cabs and I will see if it reproduces for me.
Jerry McClain
Okay I will do so. What you have is the initial cabinet saved as it was when I inserted it. I took the cabinet that is on the left and resized it in the cabinet editor, changing the left stile and the width. I then saved it under the new name of vanity ctr 18.25 and tried to insert it. I then had to reopen it and fix the height and that is what you will see when you open the job.
Thanks for looking at this for me
Vanity Ctr 18.25.hsf
(2.08 MiB) Downloaded 607 times
Kappy Vanity 2.esj
(6.07 MiB) Downloaded 624 times
JLM
