i have not been able to find the pattern with dadoes... some start at the end of a dado, some start in the middle. is there a reasoning behind the starting location?
Control nesting takes the best rout it see's fit, while also trying to implement the Ramp value in the SETTINGS dialigue. This why on shorter dados it will likely start on either end, then on longer dados it may start in middle.
