Is anyone out there experiencing mysterious back joint changing. I have had 3 instances of seed cabinets that are correct getting changed somehow . It seems to be always on the right side. Our backs are full dadoed on the sides with a butt joint on the top and bottom. Then sometimes the right side shows up as a butt joint, I wish we could lock this function so it can't change like the back stretchers.
Are you using the latest build? I have experienced these kinds of problems in the past and still get things like drawers shifting if you change the type of front and cabinets jumping out of the room if you change the doors
