I was putting shelves into a base cabinet when I realized that I had the wrong material. I changed the material and when I went to check the holes for the adjustable shelf it had only placed holes on one side of the cabinet. Has anybody else experienced this. To fix it I just deleted the shelf and replaced it and the holes were fixed.
1dwr base std dwr.jpg (14.4 KiB) Viewed 4670 times
First of all this is a cabinet from somebody else, when I loaded it into the program it came up with a material that was not supposed to be in this cabinet. When I looked at the shelves I realized that it had the wrong material. I was in the shelf and partition editor so I clicked on it and went to construction settings, it had the right material showing in the dialog box so I just clicked okay. It changed the shelf to the right material and I for some reason decided to check the holes and it was only on the right side. I stopped there, saved the cabinet and posted it. Then I went back and deleted the shelf and replaced it. This is an acceptable work around but what about the folks that just make one side invisible to check the holes and they pick the one that has none. I used transparent and it just screamed at me.
You are going to think I am crazy but I did post the one with half the holes. I downloaded it and saved it to a different file and opened it and it had holes on the right side for the adjustable shelf and not the left. When you looked it had no holes?
