Dell M90
David Werkheiser
Dell M90
I just started using a M90 with 4GB and the FX2500 card and I can't seem to tilt, rotate or zoom using the mouse and left button, as I can with my desk top. Is this not possiable with the M90?
This is my second purchase thru the Dell outlet and I saved $1,300.00 over list. No problems with my desktop in 11 months, will have to wait and see on the M90.
David Werkheiser
David Werkheiser
DaleKern
David,
I'm not having any troubles using the M90 and FX2500. With two button plus roller wheel mouse (corded or cordless) things work just fine - hold down shift then click and drag the left button to rotate/spin. Hold shift and both buttons and drag zooms in and out. I can't imagine what's up?
Dale
Dale
David Werkheiser
Dale,
Everything working fine now, I had a brain fart and forgot to hold down the shift key DUH!!!
I have another question and I have done a search. I transfered a job file over ( not quite sure how I did it) and the job had everthing in it. When I trieg to move my cabinet directory it ended up as a folder out of program.
I am somewhat computer illiterate, and could use some help on transfering files from one computer to another.
Thanks, David
Thanks, David
DaleKern
David,
I'm glad the gas has passed.
I've transferred files between computers by copying the entire eCabinetSystems_Backup directory from your old computer to the new computer. Just make sure you put them in the right place. Find the existing Backup directory and replace it with the copy from the old computer. Then fire up eCabinets and do a restore (File, restore my files) and everything should be put in the right places.
Hope this helps.
Dale
Hope this helps.
Dale
Michael Yeargain
Re:
I thought I was the only one that had these.David Werkheiser wrote: I had a brain fart and forgot to hold down the shift key DUH!!!...
Thank God I'm not alone.
How's the "mono" Dale?
"mono" is hand for those who don't know.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
32Gigs DDR4
Corsair RM650
Michael Yeargain
- DanEpps
- Company Name: Dan Epps
Re:
Actually Mike, it is mano, as in mano a mano (hand to hand).Michael Yeargain wrote:..."mono" is hand for those who don't know.
Michael Yeargain
- Al Navas
Re:
Mike, and others,Michael Yeargain wrote:So what I can't spell...
I found a recommendation for a neat FREE spell checker in one of the forums I frequent.
The spell checker is called ieSpell ( http://www.iespell.com/ ). It is terrific, and checks all the text you input into the dialog box. It becomes part of the tool bar in Internet Explorer.
FOR THE FORUM ADMINS: In fact, other forums have added ieSpell into their forum features. I wonder if the Admins of THIS forum would consider adding this as a feature?
Of course, it would STILL be each user's responsibility to check the spelling to their posts, but at least it would be right there and available to use. ieSpell would NOT check Spanish, so we would be out of luck for anything other than English.
Al
- Al Navas
Re:
Ahhh, of course! How true, Dan - thanks! And ieSpell would have missed it too, unless the user made sure of the correct use...DanEpps wrote:True Al, but mono is the correct spelling of an English word...
This is another example of a word that is a little difficult to try nail down, as it is (normally) a prefix that means one, single, or alone - but in everyday use we shorten it and use it as a free-standing word.
Then, there is the Mono (Mycetes villosus), the black howler of Central America
Al
