When I run MDF doors with a custom tool for the exterior cut I've found that the inward and outward offsets in the ecabs exterior profile setup window are backwards.
Basically ecabs will display a goofed up looking door (b/c the offsets are backwards), and it looks goofed up in profile modeler, but it machines correctly.
What's so bad about it is that in order to present a picture to the customer you have to build the cabinets with the incorrect doors and drawers and then later go back and rebuild all your cabinets with the correct doors and drawers. Real time killer.
I've emailed the ecab guys a few times about this but never got an answer on it.
I have reproduced your issue. No need to send anything in (as Justin requested). I will get it on the list to be resolved.
This may be a \"well duh\" question, but here goes: Is the additional offset required for what you are doing? Are you using inward or outward additional offset? Are you applying radius comp? Could radius comp possibly get it accomplished until the issue is resolved?
I am using an inward offset to achieve an outward offset. I am not using radius comp and it will not achieve the appearance I want right now, but I appreciate you thinking about a work around.
Thanks so much for \"putting this on the list\". It's been driving me nuts for a while and it's nice to know I'm not crazy
