Text font in LDE?
Brian Bauer
Text font in LDE?
Post by Brian Bauer »
is there a separate dialouge box for font in text and dimensioning in the LDE it is a pain to go back and forth changing the font:(
From the text window and the dimesion area.also is there a refresh botton or key in the LDE when changes are made to the settings?as in default settings to change them globally?
Brian Bauer
You mean like this?
Brian Bauer
Exactly, but is there a way to control the text separate from the dimensioning numbers.
Brian
Thanks Dan
Yep...after you add dimensions and your text, select the text and you can change the size, font and color separately from the dimensions.
Brian Bauer
I know that :oops: but I was wondering if there was a separate control so I would,t have to go back and change it.
Brian
Michael Yeargain
Post by Michael Yeargain »
Brian,
The \"text\" button is for both numerals and text.
When I do my drawings I position all views as the way I want them. Then I do all dimensions then text.
I also have a DXF file for landscape and portrait that has all my company information on it, I import this DXF file and it places it exactly on the page where I need it. Also DXF files in the LDE can be resized. So this single import does most of the text for me.
TurboCad is less than $100.00 and you can create DXF files to your own need.
This one is just a sample
LDE.zip
(137.2 KiB) Downloaded 679 times
Re:
Brian Bauer wrote:I know that :oops: but I was wondering if there was a separate control so I would,t have to go back and change it.
Brian
I think I remember (if I didn't forget) that the LDE is one of the areas for big improvements in either 5.2 or 6.0. Maybe it will have better dimension and text editing capabilities.
Your tag line, "Wood is wood, particle board is just dust", so is MDF :wink:
Brian Bauer
Yes dan it is but it is eucalyptus dust not pine :lol: , and i only use it for a face frame assembly table anyways.
Also a pic of the messy shop(closet I work in)...:)
Brian
work pics 044.jpg (854.1 KiB) Viewed 8603 times
Re:
Brian Bauer wrote:Yes dan it is but it is eucalyptus dust not pine...
Then how come it doesn't smell like Hall's cough drops? :lol: But then, particle board doesn't smell like pine either, does it?
