is there a way to create dovetail drawers for a corner unit (inside corner), where the drawers pull-out 45 degrees to the cabinets on either side of it?
So basically it would end up being a 5-sided drawer, with 2 fronts which extend back into the drawer box? I know it won't be possible to create a dovetail joint where the fronts hit the sides on a 45 degree angle, but I would like to be able to create the rest of the drawer box if possible. I don't want to cut all the bottoms seperately to get the front cut in them, and I don't really want to cut the fronts seperately either... kinda hoping there is a way to set it up easier.
Have I been even slightly clear with what I am asking?
Mark,
I understand what you are saying. But Ecabs does not support this type of drawer box construction at this time. This request is on the list, but the list is long. Thanks for your input!
If you open up a corner cabinet and try to add a drawer box, the software will tell you that ecabs does not support the action. You can add drawer boxes to angle front corner cabs, but not the corner front corner cabs.
I ended up entering a dovetail drawer without a front, then creating a second drawer with just a side and back(which they can use as the 2 front pieces). The guys in Specials Dept will just have to cut some miters and pin them together... and cut the bottom to fit. Shouldn't be a big problem for them. I guess they'll just have to learn that I do have SOME limitations
