Damon Nabors
Posts: 923 Joined: Wed, Apr 05 2006, 5:50PM
Post
by Damon Nabors » Fri, Jan 11 2008, 10:08PM
How do you open a .dwg file?
Damon Nabors
Terry Davis
Posts: 179 Joined: Thu, Oct 11 2007, 7:33PM
Company Name: Penn Laminates
Post
by Terry Davis » Fri, Jan 11 2008, 11:45PM
.dwg files are native to Autocad, there are some free viewers on the net..
Posts: 1896 Joined: Wed, May 18 2005, 7:54PM
Post
by Rick Palechuk » Fri, Jan 11 2008, 11:55PM
You need to import it to the part editor.
Post
by Rick Palechuk » Sat, Jan 12 2008, 12:00AM
As Terry mentioned you can go to Autodesk and download there free viewer.
Posts: 4764 Joined: Mon, May 09 2005, 7:33PM
Post
by Kerry Fullington » Sat, Jan 12 2008, 7:42AM
Rick,
You can't open a .dwg in eCabinets, only .dxf
I use Intellicad to open the .dwg and then save it as a .dxf
Joseph Fusco
Posts: 71 Joined: Tue, May 17 2005, 2:19PM
Post
by Joseph Fusco » Sat, Jan 12 2008, 10:12AM
You might still be able to get a copy of Intellicad 2000 which was free. I used to have a copy on my HD. There are also some other free cads that will let you view dwg and save to dxf. You just have to do a Google search.
Post
by Kerry Fullington » Sat, Jan 12 2008, 12:23PM
HERE is a link to download the old free version of Intelicad.
Damon Nabors
Post
by Damon Nabors » Sat, Jan 12 2008, 8:09PM
Thanks Gentleman, I will give it a try.
Damon Nabors
Damon Nabors
Post
by Damon Nabors » Sat, Jan 12 2008, 8:57PM
Kerry, I downloaded the link. I opened the .dwg file and then "Saved As" to the desktop as a .dxf, when I try to open the dxf in the parts editor on a display board, it never opens, what am I doing wrong? Thanks for any advice you can give me.
Damon Nabors
Post
by Kerry Fullington » Sat, Jan 12 2008, 9:33PM
Damon,
The .dxf file can only be 2D. I think there are problems also with multiple layers.
You might also make sure that the placement of the .dxf is at 0,0 on your grid
It might be opening the .dxf out in space somewhere.
Post your .dxf file and I will see what I can come up with.
Damon Nabors
Post
by Damon Nabors » Sat, Jan 12 2008, 9:41PM
My Kids wanted to see if I could cut the world map on a sheet of plywood. And I found this .dwg and was going to try it.
I tried to upload the attachment, but it won't let me. This what it says every time I try.
The extension dxf is not allowed.
Damon Nabors
Joe Soto
Posts: 367 Joined: Thu, May 19 2005, 7:50PM
Post
by Joe Soto » Sat, Jan 12 2008, 9:51PM
Damon, you need to zip the file, or you might be able to trick it by renaming it to something like .txt . By the way I have a world .dxf if you need it. Joe
Damon Nabors
Post
by Damon Nabors » Sat, Jan 12 2008, 9:56PM
Joe, if you could sent it to me, that would be great. My son has a school project and wanted me to cut it out on a sheet of plywood. His school mates say its not fair that he has the tools to make all the cool projects. They come to school with cardboard cut outs and we show up with elaborate displays.
Damon Nabors
Joe Soto
Post
by Joe Soto » Sat, Jan 12 2008, 10:03PM
Here you go
Damon Nabors
Post
by Damon Nabors » Sat, Jan 12 2008, 10:15PM
Thanks Joe.
Damon Nabors
