The problem i'm
It is easier to install the moldings in the cabinet editor and to delete those non-needed for the floor plan configuration but the result turns out to be a little bit off realistic in some cases!
So, what would be the easiest way to fix this? Should the molding editor in the CL be more accurate with some sort of an automatize layout section that we could give proper hight for different moldings and they would snap them-selfs to the cabinet layout? Can it be done? I mean by this, like with the counter top option!
It's only a suggestion for the other version coming up but it would be the best way to do it with out loosing to much time!
Tks guys and if you have some trick to give me for now, it would be appreciated a lot!
Francis
