cant get molding on bottom rail
Sam West
Post by Sam West »
For some reason I cant get molding to go on the bottom rail. Don't have any trouble with the top. Whats my problem?
thanks in advance for the help
Re: cant get molding on bottom rail
Did you select a default bottom molding? Did you set the distance from the bottom to mount it?
Sam West
Post by Sam West »
Dan I go to the same place where I select top and have no problem with the top molding. I select the molding and set it as default and the molding editor tells me to select molding base molding and when I do it puts it on top of the top molding. The default says bottom and the molding editor says base is there a difference and there is no place that I found that tells me where or how far from the bottom to place it so I am probably doing it wrong but like I say I don't have no problem with the top
As you found, there are buttons for setting the default molding for top, middle and base. There are also buttons for adding top, middle a base moldings.
Before adding each molding, however, you have to set the distance to locate the molding from either the top or bottom of the cabinet as shown in this image:
placing molding.jpg (54.49 KiB) Viewed 5568 times
Sam West
Post by Sam West »
Right there before my eyes. Is there anyone else this dumb? and Dan I do my reading and research before I post a need.
Thanks for all the help.
Sam West
Like I said in a post to someone else this morning, we've all been there Sam... :wink:
