Wacky drawer front won't behave!
Brian Bauer
Post by Brian Bauer »
maybe it is just too late to be working on ecabs after a full days work;(
But can someone tell me why this particular drawer front, added as a display drawer front ,won't show the grain horizontally?
Stll making silly mistakes,but this new puter makes em faster than ever :D
Brian
johnson vanity.jpg (18.17 KiB) Viewed 3671 times
johnson vanity.esa
(436.02 KiB) Downloaded 335 times
Justin Melhiser
Re: Wacky drawer front won't behave!
Post by Justin Melhiser »
Brian
I was looking over you file and noticed that if I delete the bad drawer front and add a new one, the grain is rotated the correct direction. Give that a try and let me know. I will have to programmers check in to this file as well.
Brian Bauer
Justin,How are you adding the drawer? it does not highlite,so can i safely assume you mean delete and re add in display item a drawer front?
Is there any plans ,anytime soon to make cabinetry stepped without having to heavily edit and assemble by hand?
Just curious :idea:
Brian
P.S. when i deleted it and re added it before i posted yesterday it just flashed correctly a second then turned vertical on me go figure.
Justin Melhiser
Brian
I just clicked on the old drawer box and deleted it. The I went to load item and selected door/drawer. I then added my drawer. It seem to work fine, if you still need some help you can give me a call when you get a chance and I will go over it with you.
