Vacuum Pump
Terry Davis
Company Name: Penn Laminates
Vacuum Pump
Post by Terry Davis »
Can the exhaust outlet on our 18hp Becker pump be unbolted and rotated 180 degrees so that it blows out our garage door instead of into our shop. There is 4 bolts on top and it looks like it can be done but we don't want to void any warranty. In the winter its bonus heat but now its too warm to blow into the shop.
Damon Nabors
Re: Vacuum Pump
Post by Damon Nabors »
Just exhaust it into the paint room, it helps cut down on the drying time. :D
Damon Nabors
Will Williamson
Re: Vacuum Pump
Post by Will Williamson »
I thought of threading a 90 degree elbo in to the end
Will
http://www.willmade.com
Todd Miller
Re: Vacuum Pump
Post by Todd Miller »
Terry Davis wrote:Can the exhaust outlet on our 18hp Becker pump be unbolted and rotated 180 degrees so that it blows out our garage door instead of into our shop. There is 4 bolts on top and it looks like it can be done but we don't want to void any warranty. In the winter its bonus heat but now its too warm to blow into the shop.
Yes Terry you can do that.
Michael S Murray
Re: Vacuum Pump
Post by Michael S Murray »
I positioned mine a couple feet from a outside wall and then attached a couple pcs of pvc on mine and run them outside in the summer and just disconnect them in the winter. Works like a charm.
Mike Murray
mike@versatilecabinet.com
Neville Bastian
Re: Vacuum Pump
Post by Neville Bastian »
I have always thought the exhaust air on the vacuum pump was wasted but would be ideal for a platform lifter like a hover craft for moving packs of material. I think someone has already done this using compressed air for moving machinery.
I did try making a hover craft using a leaf blower/vac. It did work lifting a average guy but it developed a few air leaks.
Maybe one of the adventurous Thermwood users might make better use of the exhaust?
Regards
Neville
Neville Australia
Michael S Murray
Re: Vacuum Pump
Dont give them any ideas Neville, one of them is already running his car from Mcdonalds and amusment park used cooking oil. They need to have no other distractions than e-cabs. :P :P
Mike Murray
Neville Bastian
Re: Vacuum Pump
Hi Mike,
So a hot air balloon is out of the question then.
Maybe Thermwood could market a blow up advertising sign that can come with a new Thermwood thats says get your Ecabinet cutting done here.
Catch ya latter
Regards
Neville
Neville Australia
