Floor extends past walls
Any ideas why the floor would be larger than the walls in this room?
test 2.jpg (94.17 KiB) Viewed 6172 times
test stuff 2.esj
(524.02 KiB) Downloaded 455 times
Damon Nabors
Re: Floor extends past walls
Post by Damon Nabors »
Rick, if you ever decide to expand or remodel in the future, the floor is already there. :D
Damon Nabors
Jean G Voyer
Post by Jean G Voyer »
Rick,
I wish to know how it happened. Sometime I like to have the floor going further than the walls because of some open spaces I am working in.
Jean-Gabriel Voyer
Janot Interiors Ltd
www.customcabinetscalgary.com
It kinda screws you up when your using the position on floor numbers. :wall:
Sergio Fetter
Company Name: Two Mile
Post by Sergio Fetter »
Rick,
It seams like you had a bigger room; then you made a smaller room. It has happened with me many times, for some reason the software doesn't register what is going on.
I would delete the whole job and start all over again.
Sergio Fetter
Designer Specialist
Ram 3GB - Windows 7 32-bit
Hey Sergio, check out the post "Floor size bug". :wink:
Walker T Scott
Post by Walker T Scott »
I’ve got this issue listed for the programmers. I believe this was caused by creating walls smaller than 56”.
Thanks Walker.
