Positioning water pipe
Mike Snodgrass
When I select the water pipe in elevation view. It no longer shows up in the positioning boxes. What can I do to get the correct positioning?
Re: Positioning water pipe
Hey Mike, place the pipe anywhere in elevation view then hit Esc, then hilite it, from there you can enter your position dimensions.
Mike Snodgrass
Rick, I did this as I have for about 3 years but it isn't showing the dimensions to the left.
Just a note. The snap marker was until I lengthened the wall by 1/2" and then it doesn't either.
I entered three more pipes to see if they would and they wouldn't either.
By the way, I'm liking most of what I'm seeing though!
Sergio Fetter
- Company Name: Two Mile
Hey Mike,
Try out in a different job. Sometimes my computer acts crazy for somethings and I just need start all over again.
Sergio Fetter
Designer Specialist
Ram 3GB - Windows 7 32-bit
Designer Specialist
