Mortise/Tenton in face frames.
Sergio Fetter
Company Name: Two Mile
Post by Sergio Fetter »
Hello Everyone,
Please check this cabinet out. I have been working on it and I have not been able to make the face frames m/t. I fix it and next thing I now it is back to butt joint.
I must be doing something wrong or there is something else going on that I do not know about.
Thanks!
SB_42.hsf
(874.02 KiB) Downloaded 343 times
Sergio Fetter
Designer Specialist
Ram 3GB - Windows 7 32-bit
Walker T Scott
Re: Mortise/Tenton in face frames.
Post by Walker T Scott »
Sergio
You have your FF material set to sheet stock. Only board stock can have M/T construction and sheet stock can only use puzzle construction.
Sergio Fetter
Walker,
Thank you very much for the tip. I couldn't figure out what was going on. :wall:
Sergio Fetter
Designer Specialist
