More bugs.....
More bugs.....
I can no longer get ecabinets to nest any sheet material. Also when I make up a cost sheet, there is no sheet material at all listed as a cost for the kitchen. So I tried making a cut list to see what that does.... here is what it generates:
Cut List
Job:C:\Program Files\Thermwood\eCabinet Systems\Kitchen Designs\kitchen.esj
generated by eCabinet Systems
Monday, June 02, 2008 07:52:58
Export Cutlist To Excel
Sheet Stock Summary (Qty. Based on 68.00% estimated yield)
Qty. Material Total Calc. Area (Inch2) Length Width Thickness
5 5/8 White Melamine 13618 25/32" 96" 48 1/4" 0 5/8"
-2147483647 5/8 Red Oak -2147483648" 96 1/4" 48 1/4" 0 5/8"
12 23 3/4 White Melamine 18616 1/2" 96" 24" 0 5/8"
4 1/8 Fibrex White Backing 10496 9/32" 96" 48 1/4" 0 1/8"
2 Oak - White 5009 1/4" 96 1/4" 48 1/4" 0 5/8"
8 11 3/4 White Melamine 6007 3/4" 96" 12" 0 5/8"
1 15 3/4 White Melamine 918 21/32" 96 1/2" 16" 0 5/8"
1 Non-Existant 82 1/4" 96 1/4" 48 1/4" 0 5/8"
2 3/4 Generic 3903 5/16" 96" 48" 0 3/4"
Cut List
Re: More bugs.....
That didn't work so well...... Things are a little hard to understand in that last post. What I was trying to show is that some of the numbers make no sense...
For example, ecabinets thinks that I am using -2147483647 sheets of 5/8 Red Oak (that is a negative number, not a dash...) I have been rebooting and restarting ecabinets to see if that clears anything, but it doesn't seem to make any differance.. Hmmmm......
Re: More bugs.....
Could you please post your job file or email it to me. I would like to create the cut list here and see if I get the same results.
Re: More bugs.....
Here it is Justin....
I was also having problems with this same design a few post's down. Here is the file..
- cutlist.esj
- (5.34 MiB) Downloaded 728 times
- Scott G Vaal
Re: More bugs.....
Mark,
I have narrowed the issue down to cabinets 17, 19 & 20. If you take each one of these 3 cabs from the room to the cabinet/assembly editor and regenerate them (just go to construction settings and then press OK) and return them to the room, the Cut List will then be correct. I do not have an explanation for this at this time and cannot reproduce it. Are there any specific steps you can think of that you did with these cabinets?? If you can reproduce this, please let us know the steps. HTH.
Re: More bugs.....
Sorry, I can't think of anything that I did that I don't do with every other cabinet / kitchen design.
I am wondering if perhaps I am having some issues with overheating. I have been having more and more problems with Ecabinets lately... I have just removed the cover from the tower and with limited use since, it seems that things may be running smoother. (fingers crossed...)
For example before the cover was removed I was working on another design, and could not delete countertops. I had rebooted but still had the same problem. After shutting down, removing the cover and restarting things seem to be working again. So maybe some of the problems are more of a hardware/overheating issue than a software issue.
Thanks for the great support guys....
Mark
Mark
- Michael RA Greschuk
Re: More bugs.....
I have managed to come up with the same problem. The material in question is a one sided material. All cabinets were drawn with a global white material. Some of the cabinets were then taken into the cabinet editor and had some sides changed. don't know if this is the problem or not but it was the only thing that I did differently. I then took all the individual cabinets back into the cabinet editor and regenerated the cabinets it nested fine and came up with the correct cutlist. hope this might help. I can't seem to post the before or after job. even zipped it might be too big
- Company Name: Finecraft Custom Woodworks
Re: More bugs.....
I am running into the same problem. The sheet stock says -2147483648. I know the problem is the shelves in cabinets 5 and 6. I have read this post and others related and tried regenerating the cabinets, but it still did not work. Does anyone have another solution to this?
Re: More bugs.....
I am not able to upload the file for some reason.
- Scott G Vaal
Re: More bugs.....
Fabian,Fabian Flores wrote:I am not able to upload the file for some reason.
Try sending it to cabinets@ecabinetsystems.com and I will look into it.
- Scott G Vaal
Re: More bugs.....
Fabian,
I got your job file and went to examine it and got the error "Can not find countertop body." as soon as it loads. I sent it to the programmers for further examination and it indeed has a corrupt countertop segment and it is causing the issues you are seeing. Although the effect is similar, this is unrelated to the issue from 2008 that started this post. Not sure how you got the job to this state, but if you can reproduce it, we would like to know your steps. At the current time this job is unusable, but luckily the programmer was able to manually repair this job for you. I will attach the repaired version of the job here and you should discontinue using your version of the job. The next version of eCabinet Systems will automatically repair this issue should it happen again.
- McKeen Pantry Fixed.zip
- (4.26 MiB) Downloaded 693 times
Re: More bugs.....
Thank you very much, Scott.
Re: More bugs.....
How did they repair it?
- Josh Rayburn
Re: More bugs.....
With their supreme awesomeness I think, isn't that right Scott?
Re: More bugs.....
I would also like to be supreme and awesome.
