Ok, this isn't exactly a bug or anything, just wondering if someone else has suggestions. Is there any way to rotate the layout so that I can get my point of view closer to the floor - meaning looking up at the bottom of the upper cabinets? In presentation view, I find it difficult to see the bottom of the upper cabinets, which is necessary if I'm trying to adjust the light settings in under-cabinet lights. Also, sometimes I'd just like to get a lower angle to show my clients a particular detail, which is impossible. Are there any suggestions, or is this something I can put in the programmers' ears?
Thanks everyone - Jason
Problem rotating room in presentation view
Jason Gooch
www.appleboxwood.com
Dennis Englert
Re: Problem rotating room in presentation view
There doesn't seem to be much you can do to rotate the wall/floor to view underneath a cabinet, but I did find that you can hide all the cabinets. You can only hide in the rendered view, so hide the cabinets; go to Presentation View; adjust the light; go back to rendered view, show the cabinets; then back to Presentation View.
Jason Gooch
Hey Dennis - thanks for a suggestion, I'll give that a shot. Not exactly my preferred method, but it'll probably do the trick. Thanks much - Jason.
