Lid/Top for pop-up TV cabinet
Joe Harkin
Post by Joe Harkin »
Designing an entertainment wall with a center cabinet to house a pop-up flat panel TV.
Any ideas on how to design the cabinet top with a himged cutout (door) for the TV ?
Thinking maybe I need to do the top as a face frame with wide stiles/rails, and a
flush inset door that hinges up...any other ideas ? :?
Re: Lid/Top for pop-up TV cabinet
Hi Joe
Could you show us what you have made so far. On each side of the TV
and the hole size of the entertainment wall
Joe Harkin
I'll try to plug in the files for the designs I've got so far. Changed the TV cabinet top last nite, to be a face frame with flush flat door which will either hinge at the back or be attached to the lift mechanism and rise with the TV. Any better ideas I'd like to hear them. My way is an assembly with the faceframe/door aligned to the top of the cabinet.
This is the cabinet and top assembly-
Pop-up TV Cab Assembly1.esa
(338.02 KiB) Downloaded 539 times
This is the faceframe top-
Pop-up TV top.esa
(112.02 KiB) Downloaded 579 times
George - you sure are up early
Joe Harkin
If you're interested here's a screenshot of the wall with the cabinets. That's a floating mantle between the bookcases and a made-up cabinet simulating the flat-panel TV below it.
Adams Ent wall (Small).jpg (35.6 KiB) Viewed 5662 times
Hi Joe I will get back to you I am rewireing my 3rd floor 2-Apt's.They are all away my house is 91 years old.
It was rewired in 1934 :idea: All 3 floors the ceilings are 12' high :wall: All I know is I am in the AC today the men and my son's are out in the heat :joker:
