Deleting hardware hole pattern form cabinet
Is there an easy way to delete hardware hole pattern in a cabinet?
Re: Deleting hardware hole pattern form cabinet
what type of hole pattern are you wanting to remove? Shelf holes have to be done in the shelf editor by highlighting the shelf then going into the construction settings. Hinges for doors will be removed only after you clear the default and then remove and re-add the door in the door\drawer editor. Drawer slides will be removed after clearing the default and then opening and closing the construction settings. If this isn't what you are looking for please let me know.
