How do I move the target ball?
Joe Harkin
Post by Joe Harkin »
Loosin my mind...Hw do I move the target ball out of the "current" cabinet so I can load in another one to create an assembly? Tried every key-combo I can think of, and can't find anything in help files :wall: :wall:
Walker T Scott
Re: How do I move the target ball?
Post by Walker T Scott »
Double click the target then press and hold the Ctrl key and press the right mouse button to drag it were ever you want. Then to get it back to the origin select target to origin from the mouse tier. You can also select the cabinet and move it the same way or use the move increment and arrow keys.
Joe Harkin
THANK YOU, Walter. :beer: Tried rubbing my head and my stomach backwards but didnt work... Where is that explained ? I knew I had done it before... :?
Walker T Scott
Looks like that was over looked for the manual but it will be in the third edition sorry about that.
Joe,
If you can't see the Target just hit the "T" key on your keyboard and it will highlight the target so that you can move it with the CTRL and right mouse button.
