The one problem I was having yesterday was with editing a cabinet that was already placed in Custom Layout. Bear with me, I'm going to try to explain this since I don't know how to upload files here and let someone else try to figure it out on their computer. To begin, I deleted the doors and then changed the width of the left stile of the face frame. Then when I went to add a door back, the opening still read as the size of the previous larger opening before the face frame was changed (although when I added the double doors, they were the correct size). Then it didn't seem to want to let me select one of the shelves to delete it, and when I did delete the shelves, the yellow boxes that list the shelf position still showed. I also added a mid-rail to the face frame and put a fixed shelf behind it, like a secondary deck, and it showed up with some yellow texture with words on it, instead of looking like red oak. Also, it showed through the end of the cabinet when it clearly was listed as a 3/16" deep full dado.
Is there a problem with doing too much editing to a cabinet that has been placed in custom layout? I ended up starting over in Cabinet Editor and built the cabinet the way I wanted it there first, and this approach worked fine.
Thanks again to all. I'm not giving up on eCabinet Systems!
