We order in quite a few timber and vinyl wrap doors that do not come with the hinge holes bored in them. We would like to use the G902 and simply place the doors on the table and bore out the hinges. Is this the best way? I need a little direction on how to tackle this. Any help is much appreciated. Cheers,
Dale
Dale,
You will need to draw up the door in ecabs, if you haven't already. Then write the TWD file.
Next, In control nesting>settings>Fence/Fixture locations. Change the fence location to a G902. (This will post the code out in the Flip op location) Remember to change back when running sheets.
Next, In control nesting>settings>nesting parameters area, check the "nest to edge of sheet" and in the cut parameters area, check the "No outline cuts" box.
Note: This will be for running one door at a time. You can load multiple doors into CN but just have one door checked when writing the NC code.
Try this on a scrap piece and measure for acuracy before cutting finished door.
I would think that a hinge boring machine would be the fastest method. I drilled around 40 doors in about 10 minutes this week. I have found that although the router will perform a lot of different task, it is not always the fastest tool for the job.
Hey Neville,
Yes, get a hinge boring AND insertion machine, preferably one that has air clamps, air pistons for drilling and hinge insetion.
We just sent out a casework job that had several hundred doors on it that could have very well been drilled for hinge cups on the machine, but we still prefer to use the hinge bore and installation machine for several reasons.
Do you guys have Hafale? If so, hit up your sales rep, get a $7k machine at a steep discount or free if you buy salice hinges from them. KInd of a well known secret
I agree that a hinge boring machine and inserter is the best way to go. It will bore faster than the CNC and also insert the hinge.
You can bore a door and install hinges in the time it takes the router to change bits.
Hi Guys,
Yes you are right. Drilling the holes on the drilling machine is very easy and quick. I think we will go that way rather than use the cnc drilling.
We do have a loan drill press from Hettich.
I did see a hinge machine at a trade fair that can be configured for any hinge type. It even automatically inserted it. Its a shame I don't do a 1000 doors a day to make it worth while.
Morning Neville
I agree, drilling the holes on a hinge drill machine is far quicker. But if you only have one machine and a client of yours using a different hinge than your machine is set-up, then you want maybe to drill the client doors on the cnc machine rather to go and setup the hinge drill and then have change it back again.
This is then that you want to make full use of AFL.
Here is an AFL prog I made just for that. Keep in mind:
1 Our machine default in metric
2 T6 = 8mm drill
3 T7 = 35mm pothinge drill
4 Can only drill max of 4 holes (but you can easily modify it to drill 5 holes)
Have a look at it , you can modify it to meet you machine configuration.
Hope it helps
Afl is great, I make V-groove and v-groove shaker doors and a lot of other stuff with afl, that calculates the groove spacings and panel size for you. If you have to use eCabinets for stuff like that you have to make for every different size door a complete new door from scratch.
