Steve Williams wrote:Hello All
I am interestedn in the possibility of buying a used Thermwood C40, it has a 5x5 table.
I am a newbie to eCabs, though have spent the last 2 weeks living and breathing it.
I can now do a typical kitchen/built-in ( all falt work, no curves yet ).
Anyhow, I was curious as to the actual process of using Ecabs.
As I understand it, you design in Ecabs and then hit the CNC BUTTON.
This may sound like a stupid question but does the file go straight to the router, you load your sheet and stand back?
I am sure there are many other steps involved. Are there other software programming steps ( different software ) between the design process and the final cutting process.
I take it you need actual hardware training on the C40 itself as well.
Hi Steve,
Once you design a job, you will select the Create TWD file in eCabinets. This .twd file will then get sent to the machine via cd, networking, or usb flash drive. Go to the machine and load the .twd file, nest and then press the button "Write CNC" and the program will show up automatically on the controller screen. From there you press the Start button to cut out your eCabinet job(s).
Thanks for all your help
Steve
