Why is it easier to save cabinets as an individual cabinet in a library than to save them in a room?
I have found that the quickest way to build a room is to save an altered cabinet in a library then close ecabinets. reopen the file, then delete the old cabinet and install the updated one. I had to build one room in six separate pieces as I worked my way around "failure to read parasolid file info" errors. Do cabinets get cluttered with code as they are edited?
Saving
Justin Melhiser
Re: Saving
Jay
You should always build your cabinets in the cabinet editor first and save them in a library. Once you have all the cabinets done create a room and start installing the cabinets to the room. This seems to be the best way to build a room.
Jay Burnes
Re: Saving
Yes, I always thought that that was the best way to go.
On further research, I've learned that as I edit a given cabinet the HSF file size increases. Some of my stock cabinets are several generations old, and have very large file sizes. I have begun remaking such cabinets from scratch. My average file size is dropping dramatically and my computers performance is noticeably better.
Does ecabinets software save a cabinet's build history in its HSF file?
Jay
Jay
