OK now what
- Gary Puckett
OK now what
I drew a Bathroom with two cabinets, I saved each cabinet seperatly went to the cutlist and it only showeded one cabinet.
Has this ever happened to anybody?
Joe Harkin
Re: OK now what
Gary I think you have to "Batch" the cabinets into a job then create the cutlist from the batch. Especially if you used two copies of the same cabinet to set up the room
- Kerry Fullington
Re: OK now what
Gary,
Post the job. Is it a room or Batch?
- Gary Puckett
Re: OK now what
Kerry,
Both cabinets were in the same room and the room was saved with the cabinets. The cabinets were also saved at the cabinet editor. When I looked at the cut list only one cabinet showed up I tried saving the cabinet again put it back in the room and it still didn't show up.
So I went and pulled the cabinet out of the batch and then it showed up. But every time I would create a cabinet independently and put it in the room it was fine I don't know what happened but this is getting weird.
Is it wrong to put the cabinets in a room as you create them? Here is the file
- Mike Bates Bathroom REV1.esj
- (1.99 MiB) Downloaded 644 times
- Kerry Fullington
Re: OK now what
Gary,
I get three cabinets, two cabinets in the room and one in batch.
They all show up in the nest.
- Gary Puckett
Re: OK now what
Kerry,
If you delete the one in the batch do you get 2 cabinets in the cut list?
- Kerry Fullington
Re: OK now what
Gary,
Delete your countertops and your cut list will be correct. How did you make the counter tops?
- Gary Puckett
Re: OK now what
With the counter top editor
Justin Melhiser
Re: OK now what
If you open your job, delete the right base cabinet and the one in the batch, add the right base cabinet back to the room and the cutlist will be fine as well. Was there any certain steps you followed when you added this cabinet to the room?
