"Failed to create empty document"
Nick M Singer
I found this problem discussed on earlier threads but I can not see how it was resolved. My PC was very happy minding its own business when all of a sudden I got the "Failed to create empty document" message when trying to start eCabs . I gave it a Valium but that did not work this time.
Todd Miller
Re: "Failed to create empty document"
Save this file to your desktop and unzip. Then follow the directions below.
Failed to Create empty doc. or “1607” error:
Issue:
-Receive “Failed to Create empty doc.” or “1607” Error when attempting to open eCabinets software.
Action/s to Correct Problem:
-Save to desktop and run betheone.reg
-Goto start>Run. Type regedit then the "enter" key
-(Go into Reg Editor) > HKey Local Machine > Software > eCabinetSystems > Right Click on Base Path, select Modify, to read location of eCabinets. Desktop icon must also have same startup location changed.
-Reinstall software if none of the above work.
Issue:
- Info.zip
- (697 Bytes) Downloaded 602 times
Nick M Singer
Thanks Todd I will follow your instructions
Nick M Singer
Hi Todd
Thought I would just report back that the fix did not work and will have to reinstall
Todd Miller
Nick,
Let me know if you are still having problems after the reinstall.
Nick M Singer
Ok so I got a new disc and had to do a full reinstall, so now I need a new code. The on-line code generator says i have used the maximum number of codes. I need 2 because i have also just built a new system. Quo Vadis?
Justin Melhiser
Nick
I emailed you two new codes. If they are not in your inbox, please check junk and spam folders. If they were blocked all together, let me know and I will resend them from my email.
Nick M Singer
Justin thanks for sending the codes. My new system works fine but the "Failed to create empty document" problem persists on the system referred to in this thread even though I have uninstalled and reinstalled.
Justin Melhiser
Nick
I tried to contact you but I kept getting cut off. Can you give me a call when you get a chance.
Nick M Singer
Hi Justin
Sorry you could not contact me, I have moved around a little so maybe the number you have is out of date. I only have a cell phone 270832618169. If you dont get me during the day I will call you when I get home from work. The programme starts to check for updates and then flashes the error message on startup. I ran the registry patch again, no success.
Nick M Singer
Ok now that the time limit message has begun to pop up on our screens my "Failed to create empty document" problem has fixed itself and my eCabs is working again.
