Just wondering if there is a way to select nodes and then add moulding?
Ed
Add Mouldings in Layout.
Re: Add Mouldings in Layout.
You have to select a molding in the place item dialoge box and then manipulate it into place. You can also take the cabinet into the cabinet editor and then apply molding by using the molding editor or by loading it like you would a cabinet. When done the second way, you can then rotate and snap the molding to any node on the cabinet and then return it to the room layout..
Thanks for the info.
Ed
Ed
