How do you
- Gary Puckett
How do you
How do you find where the contour is not closed? I have extended every line there is and then trimed them and it still says the contour is not closed
- Damon Nabors
Re: How do you
Gary,
Sometimes the lines will overlap each other and you will not see the problem. Another problem is splines, they cause problems also.
Damon Nabors
Re: How do you
There's a ton of stuff on this topic in search Gary. http://www.thermwood.com/forums/viewtop ... sed#p37435
- Grady Pinckard
Re: How do you
Gary,
Sometimes you will have to shut down e-cab and restart. I know you have to do the drawing again but its the only way.
Grady
Grady
- Kerry Fullington
Re: How do you
Gary,
Make sure you have Object Snap turned on and Grid Snap turned off when you are extending and trimming your lines.
There are also times when you may have two lines, one right on top of the other and this is the problem.
Save the geometry you are working on and post it. Maybe I can help.
- Gary Puckett
Re: How do you
Thanks Guys I finally got it. For some reason I clicked in a different spot and it did it
