Bad KD holes - CN 5.47
David Hall
Post by David Hall »
The "pockets" created for KD fitting holes in the attached file are bad. See code starting at Line 4209, Sheet:3 part:5 (T20) in attached CNC file.
By changing T20 to allow interpolation, we're up and running.
With T20 as pocket tool, no drill or interpolation for T20, convert line and arc to drill: On, We get two pockets for each KD hole. One looks like it might be correct. The other is a mystery... cutting into adjacent parts and creating dumpster food.
Dave
closet bad 021709.zip
(966.42 KiB) Downloaded 748 times
David Hall
Hall's Edge Inc.
eCabinets Machining Services
http://www.HallsEdge.com
Larry Epplin
Re: Bad KD holes - CN 5.47
Post by Larry Epplin »
Hi Dave. I see the problem. We will get this addressed in the next update to Control Nesting.
