Darwin Joslyn
Posts: 8 Joined: Tue, Apr 14 2009, 9:39PM
Company Name: Joslyn Woodworking
Post
by Darwin Joslyn » Sun, May 03 2009, 7:51PM
Is there a better way to apply cabinet ends other than doing the component alignment and then changing all of the insets?
Al dedenus
Posts: 269 Joined: Sun, Apr 29 2007, 8:53PM
Country: NEW ZEALAND
Post
by Al dedenus » Sun, May 03 2009, 11:13PM
I load a display panel and associate it to the cabinet in the cabinet editor, I actually find it easier than sorting all the insets to get it right in custom layout,but hey its whatever you get used to.
Brad McIntosh
Posts: 539 Joined: Wed, May 18 2005, 6:59PM
Company Name: CNC Automation
Post
by Brad McIntosh » Mon, May 04 2009, 8:28AM
How about this...
Take a cabinet and remove all but the right end.
Apply an "end" material" and adjust the parameters relative to the toe and others that can effect it's size, position, etc.
Adjust the width of the cabinet to just a little more than the maximum thickness of what you applied end material would be.
Add a USER NAME to the right end and call it "LEFT APPLIED END".
Save it to your library as "LEFT APPLIED END".
Do the above again, only with the left end and saving it as "RIGHT APPLIED END".
Then it is just a case of dropping it into the room layout or adding it to the Batch entry list.
Darwin Joslyn
Post
by Darwin Joslyn » Mon, May 04 2009, 9:26PM
Thanks, I like your approach Brad, it seems easy to follow and like Al said it's a lot of what you get used to doing.
Al dedenus
Post
by Al dedenus » Mon, May 04 2009, 11:43PM
never thought of that Brad.might give it a whirl.Seems that every time I do an applied end in CL it goes everywhere but where I want it
Iain Hall
Posts: 44 Joined: Mon, Jun 09 2008, 11:11AM
Post
by Iain Hall » Wed, May 20 2009, 11:36AM
that works really good the only draw back is that you wind up with a huge number of cabinets and I find that it gets confusing for the guys in the back
Iain Hall
Woodwright Cabinets
