Profiling in a nest
Sean O' Hare
Profiling in a nest
Post by Sean O' Hare »
When I try to apply a profile in a nest using custom tools, I get strange results. If interior & exterior MDF door tools are enabled, it will use those for 1 region each regardless of the diameter of tool. If they are disabled, the program will model a profile even if a tool to match the profile is available. Am I missing a way to nominate a tool for a particular profile? I thought it was selected based on exact diameter, but it seems not. I know I can do it in PM, but I would like to do it in the nest.
I am running PM 2.2.1, RN5.47 Ecabs build 5. Settings are metric.
A side issue, when I hover the mouse over a part in the load screen in PM, the dimensions displayed are imperial. Can be confusing.
Thanks for any help,
sean
sean
Ryan Hochgesang
Re: Profiling in a nest
Post by Ryan Hochgesang »
When nesting a door panel, you must utilize the tooling settings under: Control Nesting/SETTINGS/MDF Door Tool Options to define what tools will be used to machine a profile door in a nest. If you have additional questions regarding your file setup, you can email the design file along with the EXPORT file from Control nesting to:
program@thermwood.com for further reveiw.
Sean O' Hare
Ryan,
thanks for the prompt response. Nesting doors works fine, its other panels. For instance, a fluted pillaster with 3 identical flutes, drawn in ecabs with a 12mm spherical cutter that matches 1 set up in the machine. I expect it to make 1 pass for each flute with that cutter. Instead, the control will model the cuts using various tools.
thank you,
Sean
sean
Ryan Hochgesang
Did you check MDF Door Tooling option in SETTINGS?
