Nat Wheatley
Posts: 491 Joined: Wed, Apr 15 2009, 8:22PM
Post
by Nat Wheatley » Thu, Jul 02 2009, 4:59PM
Wasn't able to figure out how (if possible?) to remove the 45 degree clip on the back of this corner cabinet. Is there a way to do it
Posts: 4764 Joined: Mon, May 09 2005, 7:33PM
Post
by Kerry Fullington » Thu, Jul 02 2009, 6:10PM
Nat,
Open the cabinet in the Cabinet Editor
Go to Construction Settings/Corner Settings Tab
Enter 0 in the Corner Gap box
Nat Wheatley
Post
by Nat Wheatley » Thu, Jul 02 2009, 6:31PM
Very easy, thanks very much for the help.
I'm setting my right and left depth at 304mm, but the actual size of the sides ends up at 324. I had thought that the right and left depth of the cabinet woyuld match the width of the right and left sides?
Nat
Post
by Kerry Fullington » Thu, Jul 02 2009, 7:11PM
Nat,
eCabinets automatically adds enough material to the sides to cut a miter (great for face frame not so great for frameless).
Add a front inset the thickness of your material (19mm) to the left and right sides and to the top and deck.
This should get you the cabinet you were looking for.
Nat Wheatley
Post
by Nat Wheatley » Thu, Jul 02 2009, 7:15PM
Thanks again Kerry. I played around with that one quite a bit, and could not figure out what was going on.
Post
by Kerry Fullington » Thu, Jul 02 2009, 7:21PM
Nat,
I told you something wrong. The front inset for the left and right sides would be 19mm but the front inset for the top and deck would be 13.5mm
