Fixed shelf protruding from cabinet
Post by Donald Thomson »
I'm trying to get the fixed shelf in the attached cabinet to be flush with the back and front of the cabinet. But it seems to be protruding from the back by a little bit. The cabinet side is 15.5" and the shelf is 15.536". I know I'm missing something here, just don't know what?
Pat Rice Nightstand.jpg (11.84 KiB) Viewed 11306 times
Pat Rice Nightstand.hsf
(1.34 MiB) Downloaded 1022 times
Damon Nabors
Re: Fixed shelf protruding from cabinet
Post by Damon Nabors »
I noticed you also have a gap on the right side of the shelf, I went about it a little different than you, but I corrected that problem as well.
Hope this will help you
Pat Rice Nightstand_a.hsf
(90.02 KiB) Downloaded 1057 times
Damon Nabors
Thank you Damon!
I'll take a look at how you approached it.
Hi Damon,
Thank you again for your help. When I try to load the cabinet I get an error dialog that says:
"The requested change resulted in an unworkable dimension for this cabinet. Press OK to restore previous settings"
When I click OK I get a cabinet that looks like the attached JPG file. Not sure what I'm doing wrong.
