Hi all,
Just wondering why the attached job is stopping on certain sheets when it is drilling a 5mm hole at the toolchanger end of the machine.
Thanks in advance,
Paul.
Machine problems
Ryan Hochgesang
Ryan Hochgesang
Paul,
I've seen what you are telling me happen before (machine gets into tool change safety zone when in operation). This situation will occur during a off fall cut the G901 is not correct or it will occur during a drilling operation with the drill bank if you are trying to use a drill towards the front of the bank that causes the machine to get in this \"zone\". I noticed you are doing a single drill but this could be with the drill bank so you will need to check the drill bank boundaries. Normally, we will set single drilling operations up so that the main router is used. The only thing that is causing me concern is that on line 42 the machine seems to be indexing well out onto the material which I don't see causing this issue, if the line you are saying is correct.
Ryan Hochgesang
Assuming the G901 location is setup accurately, I would suggest that you setup single drill operations to be done using the main router, since we know the router will access the entire table. Otherwise if you want to continue to use a single drill located on the drill bank, make sure you select the drill with the most table access. If you are using the drill bank for drilling operations, you will need to make sure to setup the DRILL BANK PARAMETERS located in the SETTINGS of Control Nesting. When setting up the drill bank parameters, you are defining the accessable area relative to the G901 position on your machine. Depending on the location of your G901, the values may be (-). I've included a sample with/without, using the x, y shift with control nesting. I've attached some information that will hopefully help you out with understanding the settings.
- Setup DBP.zip
- (263.15 KiB) Downloaded 1944 times
