Where did my wall go.
Dickey Beckham
Post by Dickey Beckham »
Hi I have been having a little trouble cutting out a wall this will go under a set of stairs, Just about the time I get it cut out
the program shut down, so I did a cut and saved, did a cut and saved, until I got it cut out, Next I loaded the cabinets that go into it , and did a frount view, now the wall not there. I have not had much problem with this computer before, But have not cut out a wall this way either. any help thanks.
Wall c.pdf
(422.12 KiB) Downloaded 491 times
Wall a.pdf
(7.66 KiB) Downloaded 500 times
Wall 1.pdf
(8.95 KiB) Downloaded 465 times
Re: Where did my wall go.
Can you post the job file Dickey.
Dickey Beckham
I will try
Eubanks.esj
(1.5 MiB) Downloaded 499 times
Dickey,
Move your cabinet and you will see that you have left two small slivers of wall when you cut it out
This divides the wall into two separate entities and eCabinets doesn't like it.
Instead of doing all this
to do your cutout. Try something like this. Make sure your rectangles overlap to avoid the little pieces
After I re cut your wall as above I get this
Dickey Beckham
Thanks Rick and Kerry for your help, what was it, I have been using ecabinet for about three years now and I am still learning and I know that I will never completly master it , But by asking questions and checking the forums I am getting better, I have tryed other programs and sure you can make boxes with them, but with some training and some help from you guys this one you can all most do the impossibe, LOVE IT!
Thanks for the help. :beer:
