Cabinet numbers
joe breznick
Company Name: Breznick Woodworking
Cabinet numbers
Post by joe breznick »
How do I change the cabinet numbers?
Chris Harmon
Company Name: Azure Cabinets
Re: Cabinet numbers
Post by Chris Harmon »
Hi Joe,
The cabinets are numbered in the order that you bring them into a room. If you modify or change a cabinet ecabinets will automatically renumber the changed cabinet. The way that I work around this issue is to redraw the room after I have the changes that I want. If any one has a better solution please let me know. I hope that this is something that has been added in version 6.
Chris Harmon
http://www.azurecabinets.com
joe breznick
Re: Cabinet numbers
Thanks That is what I have done in the passed I was hoping that there was an easy way that I was missing. You have a nice web site Chris If you get a chance take a look at mine www.finewoodenfurniture.com I also build kitchens but never get the nice photos to put on the web. Good day
Chris Harmon
Re: Cabinet numbers
Hi Joe,
Thanks for the complaint on the website. One of best things that I was told once is to all ways document your work. It is money well spent to have a professional do the photography. It is all about the lighting.
Thanks for sharing your web site. Have you ever recieve any work from someone visiting your site?
Chris Harmon
Chris Harmon
Re: Cabinet numbers
Sorry for the typo above I meant to say complement not complaint.
Chris Harmon
Nick M Singer
Re: Cabinet numbers
Post by Nick M Singer »
Why is it you need to change the numbers?
joe breznick
Re: Cabinet numbers
Chris I do get a few orders from the website and I use it as a catalog of my work but truthfully I haven't added work to it in years.
Nick it would make things simpler when building the cabinets to have them in order. as it is now I have the corner cabinet as 1 & 2 top corners as 3 & 4 then i finish off the uppers then back to the base cabinets would be nice just to start left to right on the base then come back again L > R with the uppers. just the way my mind works.
Chris Harmon
Re: Cabinet numbers
Nick
It never fails that when I show a floor plan to a architect, contractor or homeowner they always ask why is that cabinet numbered out of order. So it does not make you look profesionial.
It also confuses the installers. For example on a job we were installing just the base cabinets that were number 1 - 12 so the installers loaded the truck with those cabinets. When they started to install they noticed that the sink cabinet was numbered #21. So they had to make a extra trip back to the shop. Also when cabinet #6 is changed to #21 you are thinking that cabinet #6 did no get made, loaded or cut. So it would help eliminate the opportunity of mistakes.
Chris Harmon
Nick M Singer
Re: Cabinet numbers
This is why I asked the question. If it is a matter of numbering the units in the drawings one can put in ones own numbers manually in the line drawing editor.
Chris Harmon
Re: Cabinet numbers
Nick,
I will give that a try. Thanks
Chris Harmon
Dennis Englert
Re: Cabinet numbers
Post by Dennis Englert »
Yes, you can add numbers to the Line Drawing or you can even shuffle the existing numbers, but the labels and reports will not change.
Dennis
joe breznick
Re: Cabinet numbers
Thanks Dennis I didn't think it would and will only add to the confusion that I already have. great program otherwise i have 20/20 and someday will have a cnc too if all goes well
