Applying ML Cambell Toner
Gary Puckett
Company Name: The Woodworkery
Post by Gary Puckett »
When you spray ML Cambell toner do you mix it with the top coat and then apply it ?
Re: Applying ML Cambell Toner
Gary, thats the way we have done it. We mix a little color with the clear, keeping a record of all the steps and amounts, then we use a small gravity feed gun to apply it.
Gary Puckett
Rick,
I was talking to another guy on wood web and he suggested mixing the toner with the vinyl sealer at a thinned down mixture then apply the top coat.
Wally Schneeberger
Post by Wally Schneeberger »
Gary Puckett wrote:Rick,
Either way would work just fine. You might even gain a little depth by adding to the sealer.
We don't use a separate sealer. We use Krystal, which is a self sealing topcoat.
Michael S Murray
Post by Michael S Murray »
We always put a clear cote over the toner coat
Mike Murray
mike@versatilecabinet.com
